Going under the Knife
Started by jrobinson, August 24, 2017, 11:11:52 AM
I bought my 2005 Ultra Classic in Feb of 2012. It had 17k  on the speedo at the time. Now at 86k I'm starting to hear the ticking of the poorly designed cam chain tensioners.  Over the last couple days, I've also heard a whine coming from the engine. Since Sandy wasn't nearby when I heard the noise, I'm guessing the cam bearings are going also.
So over the weekend I plan to tear into the cam chest and replace inner cam bearings along with the 2 cam chain tensioners. While on the jack, I'll replace the rear tire and worn rear brake pads. Hopefully all my parts will be delivered as promised.
I'll be documenting with pics and video, so stay tuned if you want to see a Harley stripped down to the bare bones.
KrisCook
Ha!  I'mmmm tellllllling Sannnnnnndyyyyyyyyy
2019 Honda Rebel 500
2018 Honda Grom
I'm pretty sure she knows that she's a whiner.
dredman
You should not ride so much.  Riding that much will KILL a moorsickle!
I can quit anytime you know.
Not much progress, but it is progress.
Almost to the bottom. Start rebuilding soon
dredman
From what I have seen so far, engine is the LEAST of your problems.
When was the last time that bike saw soap?
I dare not ask about wax? :-\
Can't wash em while you're riding.
Sent from my HTC6525LVW using Tapatalk
That's a Robinson Harley. It doesn't need soap to be cool 8)
Quote from: dredman on August 26, 2017, 04:14:16 PM
Who stole Don's password and is posting under his name?
dredman
Quote from: norton73 on August 26, 2017, 06:43:43 PM
Says the guy with a filthy sludge trap.....
I WILL see this place cleaned up  :o
dredman
Quote from: jrobinson on August 26, 2017, 05:08:51 PM
I think some of that thick layer buildup of bug juice got into your engine via osmosis, I heard it is VERY corrosive
Quote from: dredman on August 27, 2017, 10:03:22 AM
Not as corrosive as other stuff.
Going back together.
Out with the old, in with the new.
New tensioner pulled back off the chain. This makes installing the cams back into the chest easier.
Cam plate with new cam bearings back in cam chest
Primary chain installed
Valve train with the breather plates removed.
Push rods, silver for intake and black for exhaust. Push rod tubes before clips added.
