Which Tube to spare with new tires
Started by thinwater, June 28, 2019, 07:12:32 AM
thinwater
So, The Himalayan is about to get new tires, 6000+ miles on the bike with OEM tires/tubes.  I have new tube for front and rear and have been hauling them around for spares.  When the new tires go on, should I put new tubes with them and carry the old tubes for spare, or should I reuse the old tubes and run them till they give trouble then install the new tubes?
Depends on how much you enjoy taking tires off and changing tubes!
I personally hate it so I typically put new (ultra heavy duty) tubes in when I put a new tire on!  If it saves me from having to change one tube along the side of the road it is worth it!
thinwater
Quote from: Fencejumper09 on June 28, 2019, 08:59:15 AM
So then do you take your previous service tube as your spare, or do you buy brand new tube as spare?
I agree with FenceJumper although I haven't ran tubes in a while, I use Tubliss System on my dirty bikes. However before Tubliss. I always ran high quality Heavy Duty or Ultra Heavy Duty tubes. I don't want to mess around with flats on the side of the road. I think it's worth the extra money to install new tubes with new tires. Especially tires that get higher mileage like you have.
Quote from: thinwater on June 28, 2019, 09:25:37 AM
The OEM tubes are probably average, standard duty tubes. The plus side is they pack up smaller when carried as spares. For light duty offroad and street use I would think those would be just fine. If I'm on a multi-day adventure or dual sport ride in rough terrain, I'm carrying new heavy duty tubes as spares.
I carry standard duty tubes as spares when I go on longer dual sport trips because of the pack size and and weight! I will inspect my old tubes and if they look good with no rubs or questionable areas I will save them for future use when in a pinch.
You can see my spare front tube attached to the fender here haha!
If I were planning to go on a long trip in remote areas I would probably carry replacement heavy duty tubes.  I generally just carry the one 21" spare standard duty tube as it will fit in a 18" rear and get me home in a pinch.
Quote from: Fencejumper09 on June 28, 2019, 10:45:37 AM
That is about what I do. Tubless is not available for the A.T. (or the last time I checked it was not) so that's out. On the first tire change I put the standard  21" tube in my front fender bag for a spare and a HD for the front and rear tires I put on. On the next tire change I once again bought HD tubes for the front and rear, then put the old HD 21" tube in my front fender bag then tossed the OEM tube in the garbage. I always change the tubes when a tire change is needed. I always keep a spare or two tubes in the size's I need at the house. On both the old and new tubes I will use a bit of baby powder to coat the inside of the tires... sort of like a dry lube deal.  ;)
Jwwr
I wouldn't tell you NOT to put in new tubes every tire change, but I have ran the same tubes in my wr250r for over 25,000 miles and I don't how many sets of tires. Never had a tube fail! Only one flat and that was from a screw. I also don't run low tire pressures. YMMV!
Jwwr
I also should add that I use a liberal amount of talcum powder on the tubes before I mount the tires.
