Good to hear !
Changed the rear turn signals to some oem KTM signals for the 07. Now I'm melon shape signal free !
Dropped a couple phones on the bars to make sure I could stand having two going at once.... Self guided hard enduro is coming up and I want to have redundancies.
Swapped to a higher compression head...
Cut off an old kips cover to make a 1.5cm spacer for the resonating chamber. Supposedly this makes for a much more grunty bottom end power range. Between this and the higher comp head, it works very very well. I tested jetting and the other two changes on some harder single track last weekend and was happy with the tractor abilities being improved a good bit.
Quote from: kylepeterson on February 06, 2018, 07:39:17 AM
I have zero machining abilities, this fascinates me.
I installed some CRG Lanesplitter bar end mirrors. Now I can see behind me and they give it a much cleaner look.
Quote from: merc16 on February 18, 2018, 12:31:35 PM
Stock mirrors suck so bad they shouldn't have made it to production
#276
Did some freshening up on the two-hunny...
New reeds and a JD jet kit
Motoz Arena Hybrid / Tubliss combo for the rear (old vs. new)
Quote from: KevinB on February 23, 2018, 06:40:51 PM
COOL! How are you likeing the Tubliss system? Does the 100psi "mini tube" hold the tire well? How low do you run the pressures in the tire? 8psi, 10psi, or higher?
I wish they made one to fit the A.T. ...probably wouldn't help my riding though. It would just remove 1 more excuse for why I sux.  :D
#278
Love it so far...I used it on  my Huskys (510/610) and currently have it on my Husaberg and the rear of the 200 (I have the Tubliss for the front, just waiting until I need a tire to install). I like not having to carry spare tubes...I carry a rope plug kit and a CO2 inflator.
I check both bladders before each ride (most of the time). I put @ 110 psi in the high pressure bladder, and it usually loses @ 5 - 10 psi after about a week or so. The low pressure bladder stays consistent. I run @ 8 psi for pure off-road, and @ 10 - 12 psi for dual-sporting.
Saturday actually. I had broken right rear turn signal stalk and burned out headlamp on the kLR. So I order an OEM turn signal, you can't just get the stalk. I put that on
unbolted the cowling and pulled it forward to get to the bulb only to discover that this resulted in breaking a front turn signal stalk
Examination of the remaining intact stalks revealed that they were cracked and rotten. Not wanting to spring for more turn signals, I ordered this KLR turn signal stalk delete kit off of ebay, they do away with the stalks and the signal sit closer in, I should get them Monday. Since the cowling was pushed forward, I took the time to check the wiring on my racing dash.
Changed a tire, but didn't use the SpeedyR valve stem insertion method, quick and easy never seems to work for me.
Quote from: KevinB on February 23, 2018, 10:29:41 PM
I have heard that with the high pressure bladder that every time you check the pressure you lose nearly 5psi! May be internet bs but with the low volume I believe it!
#281
I use a bicycle floor pump with an integrated gauge on the high pressure bladder. On the low pressure bladder, I use a tire gauge and loose @ 2 psi each time I check it.
I have a set of Tubliss ready to install when I need new tires on the YZ!
So what do you consider the benefits of Tubliss on a dual sport?
I love it on my single track bike. I have front and rear and go as low as 5psi with a tire that has stiff sidewalls. I've even ran 0 psi to get up an extremely muddy hill in a race. I feel like the number one benefit of Tubliss is being able to run low pressure. No need for that on a dualsport though. If it wasn't for this I would just run a heavy duty tube.
I would still suggest carrying a tube with you. A 21 inch will work in the rear in an emergency. Just in case you pop a bladder. Otherwise, you are screwed.
Springer, I really don't see your AT gaining any performance benefit from running a Tubliss.
For local D/S riding, I just carry the plug kit. I figure that should cover most punctures, and if the hole is too large the high-pressure bladder provides a full bead lock to run it flat until I can get home. In the event the high-pressure bladder gets toasted, I figure I'll call for a ride or tow. :)
On longer trips away from home, I still carry either a tube or a spare high-pressure bladders and spoons.
