0 Members and 39 Guests are viewing this topic.
#285
I guess I should add to and clarify my post above.
When I say I'm using Tubliss for "dual-sporting", I mean on my smaller tagged bikes that will usually get ridden from the house to the trails and possibly on some gnarly terrain (and pavement back home)...it eliminates the need to air up/down.
I'm about to mount some new tires on the 640 and will be continue using UHD tubes on it. I run more pressure in it because of the extra weight and the fact it sees much more pavement...the gnarliest stuff it will usually see is fire roads/jeep trails, so ultimate traction is less critical and I just leave the pressure @ 18 psi.
Tried to help a friend figure out his 2015 250XC non running issues last night. @bblass , @IceCold4x4 and myself have already put a new top end in it! We observed weak spark and pulled the stator to find some wires rubbing on the flywheel. We tried to clean up the wires and reroute them but the bike still won't start.
Our professional opinion is that when the wires shorted to the flywheel, they fried the stator. I really don't know!
 Good possibility. I know you probably don't have one, but Fluke makes a small voltage detector that can be used by just placing it on the insulation.
So someone holds it against the spark plug wire, then kick it. It don't light up? Place next to the coil and repeat. No light? and so on and so on, moving on down until you find voltage. (If there is any).
I have a couple at work. I can bring one home tonight and you can get it from me tomorrow. (I will leave for work Friday @ 1pm)
Message me if you want to borrow it. I get an email on my smarty-pants phone when I get a pm here.
#288
Quote from: kylepeterson on March 05, 2018, 05:44:53 PM
I just want to point out a couple of things....
That's Kevin's totally skint rear tire, not mine. Take a long long look folks, this is an anomaly in our universe. Normally a Kevin machine has tits on it, and if there aren't tits it's because it's on a machine about to have tits installed.
@kylepeterson
Because I felt like I was letting Kyle down...  :(
New Tractionator H/T rear and Pirelli MT21 front combo
I had an unfortunate meeting with Mr Tree and Mr Rock at dirt school last weekend
While that little hole may not look like much, it was enough to make my bike puke coolant down the trail.
Using a thing gauge wire, I slowly pushed a bead of JB weld down the broken channel. So far, so good! Here's hoping it holds up on the next ride. I'll have an egg in the truck just in case!
Quote from: KevinB on March 08, 2018, 04:05:49 PM
@kylepeterson
There we go, fresh tits ! :-)
Quote from: bblass on March 14, 2018, 08:28:58 AM
Jesse Can Mexi CAN !
Gotta love jbweld!
I heat and beat on my old crooked FMF pipe today so it would align with the head again. Got it really close and noticed I had some flat stock laying nearby , so I made a torque ring or two.
Basically you use a hole saw to drill a 1 1/2" hole, then a 1 3/4" around it to produce a thick ring out of 1/8" aluminum stock.
The aluminum provides a cushion from all the hammering the pipe does to the head.
Longer pipe is supposed to make more torque too , but I'm skeptical as always. It's only 1/4" , and we all know that's not gonna make it groan any louder.
Took her for a spin to the soccer complex and ran into my buddy Ben. He was not on a bike, car, or even a motorized skateboard. He....
Was...
Running ???
I didn't see any head hunters or wild pigs behind him, so maybe he's not as smart as I thought he was ;-)
But it's always fun to see dirty bike buddies :-)
Quote from: kylepeterson on March 14, 2018, 07:51:01 PM
Pictures man. I need pictures.
I spent all evening rattle canning, sanding and then polishing.
Not there yet, but way better than it was!
Quote from: bblass on March 14, 2018, 10:17:01 PM
:P I guess this is the drooling emoji ? Nice V-twin collection !
Recovered my seat with a Seat Concepts kit.
Also made two tool tubes out of 3" PVC.  Used primer and glue to attach an end cap on one end and a threaded cap on the other end.  Glued some foam on one side.  I'll carry them in my Sweet Cheeks seat widener.  They should be waterproof.
Goat, that thing is going to be the Colorado Cadillac!!
Added headlight protection and fender pack (for spare tube and lightweight tire changing items).
Also made a longer wrist strap for my GoPro remote using 1" web strap and buckle from Hobby Lobby.
Just a little tire replacement for the Super Tenere. The OE Bridgestone BattleWings managed to give me 5882 miles. Trying the Michelin Pilot Road 4 Trail. I have no idea what the difference is over the standard PR4, which is available in the 110/80-19 and 150/70-17 sizes, other than the description that the PR4T is "designed for Adventure bikes that are ridden exclusively on the road", but I figured I'd go with them. The price difference was about $3.00 each.
